I used the bed sides on my harbor freight trailer and $12 of lumber to make a car trailer.
Towed it home and parked in the front yard.
Brakes first.
If anyone has the following for sale, I would like to talk to you:
Front hood latch
Front hood emblem
Air cleaner housing
Muffler
Rim/Wheel
Front bumper
Boot for steering rack
Rear seat any condition
Battery bracket
All boots for engine ducting
Left door striker-the round pin
Hub caps
Young steering wheel
Young bucket seats
Dome lens
Parking brake cables
Headlight eyebrow
Points
Condenser
Distributor cap
Rotor
Rubber timing inspection plug.
Cleaned oil tank and put in fresh oil. Fresh oil in transmission. 12 volts to battery lead, ignition on and no power to coil. Pulled the spark plugs and they had never been fired (probably why the vehicle was parked in 1996). Put 30 weight into cylinders, by pass ignition system with 12 v directly to starter and turned engine over a few times. 12v to coil and no spark. Adjust points, no spark at points. Clean points with point file and now spark at points and plugs. Open carb butterfly, spray fuel in carb throat and the engine runs! Working on fuel tank , fuel diaphragm disintegrated. Awaiting new fuel diaphragm from Jon.
Mike
