New Sedan owner
New Sedan owner
Hi from South Dakota!
I purchased a 1970 Subaru 360 from an estate auction this last November and am only the second owner in 49 years. The car was originally white but painted orange some time ago as it has completely turned to red in most spots. I have already removed the front seats that were to large for the car, i think they were out of some mid 80's car. the drivers side wheels are locked up, i'm sure from sitting. i have been oiling them for a few weeks now that its warmer out and will try and get them freed up soon. motor still turns over and ran when it was parked.
Anyone know someone with a sedan front seat?
i'm sure i will have more questions, i have already skimmed through the book of reprints.
Dan
Dan
Re: New Sedan owner
Dan Welcome aboard ........
I may have a recoverable one......But the shipping from Oklahoma would be expensive. Maybe some one closer has one??
Re: New Sedan owner
Welcome to The Club! We are all here to help.
Re: New Sedan owner
I PM'd you.
Re: New Sedan owner
Welcome to the Club... from downunder, Dan - I see your problem, it's the steering wheel is on the wrong side!
Re: New Sedan owner
Haha, i would have loved it even more if it was a right hand drive. As if they are not unique enough already.
Working on the drivers side brakes today trying to get them freed up.
Re: New Sedan owner
Welcome, I also have some seats but need covering so basically frames and springs. If you can't find any closer let me know. I'm in WV
Re: New Sedan owner
i'll give you seats for free
Re: New Sedan owner
Dan - please PM or e-mail me.
ed
ed
Re: New Sedan owner
I have all 4 wheels moving now, the back driver side is still really tight but it is moving. Going to try and get it running next and then onto the brakes, i know the pads need to be replaced or relined for sure as the ones on the driver side were swollen up and corroded. Is there someone who relines the shoes? also still looking for a seat.
Re: New Sedan owner
If the motor turns free I'd get a look down in the cylinders. and take off the intake and exhaust to see if there are any contaminants in there. Animal nests and such. If all is clear I'd pull the oil pump and make sure it's getting the propper flow rate and operates freely. If oil pump is good, put oil in under the pistons into the crankcase oil the piston tops rotate it a lot then put oil pump, plugs, intake exhaust all back on. Clean the carb. and hook it up to an external fuel source. I'd use like 30:1 mix gas and oil to start it on. Replace all oil and gas tubing so as not to introduce crud in the lines to the engine.
