How to locate Vin Number on 360 sedan
sriwelaratna
#1 Post by sriwelaratna »
I acquired a Subaru 360 sedan a few months ago and joind the club. Can someoen help me to locate the vin number on the car which I hope will lead me to identify the year of make? The engine is claimed to be running, the gas tank has holes in it and there are lots of rust areas to be sorted out. Would someone have a gas tank for sale? Can someone aso let me know if it is possible to buy the windscreen rubber gasket and the rubber for the two side windows that open?
dmkberger
Re: How to locate Vin Number on 360 sedan
#2 Post by dmkberger »
The VIN plate should be under the hood, under the spare tire. It is a very flimsy aluminum plate glued to the firewall. Rubber for the side windows is not available, have to locate good used pieces, if you can. It is made of unobtanium and very hard to find. The windshield rubber is not available in the original form, aftermarket is available, check in the posts, someone in the club has it... Good luck with the car
Was 2 360's
Now 4
#3 Post by subaru360nut »
If you can't find it from this info, E-MAIL ME so I can return a photo to you by e-mail of the page from the owner's manual shat shows the location of the sedan VIN.
If you happen to have a truck or van instead of a sedan, I can show you the location of that also.
Ed Parsil, Tucson AZ (see ROSTER for my e-mail address)
#4 Post by kjrcace360fan »
dmkberger wrote: It is made of unobtanium and very hard to find. The windshield rubber is not available in the original form, aftermarket is available, check in the posts, someone in the club has it... Good luck with the car
"unobtanium" They sure used a lot of that stuff as near as I can tell. Possibly main ingredient. :lol:
Chassis Number location on my sedan:
sriwelaratna
#6 Post by sriwelaratna »
Thanks for the helpful comments and the unhelpful but very funny one with the name of the element that had eluded me all this time. In two days time I will get an opprtunity to check out the vin number. I will post my findings.
#7 Post by Garm »
There is a thread where Ed is collecting all known VIN's, post up in there, or email him so he can add you.
#8 Post by books1 »
Velecasa wrote:
books1 wrote:Chassis Number location on my sedan:
Hi
I saw a post that u posted a pic of a spot where vin can be found
obviously the plate ay top in front trunk
But where is that pics
How many spot are there where vin is avail ?
Help will be greatly appreciated
Can anyone enlighten Steve on the above points? I think he is asking about van and or truck Vin locations, but I am not entirely sure. My knowledge of Vin location(s) is confined to sedans only - Sorry!
#9 Post by Sigmaz »
He mentioned that he acquired a sedan a few months ago.. so I'd imagine that your info was somewhat helpful.
#10 Post by Garm »
VIN stamped onto frame in the sedan front trunk:
Velecasa
#11 Post by Velecasa »
Very helpful need for sedan thanks
Velecasa
#12 Post by Velecasa »
Is that spot and plate above jack / brake fluid receptacle only spots or is there more ?
Velecasa
#13 Post by Velecasa »
I don't know why but when try to message get error messages
[/img][/url]
Velecasa
#14 Post by Velecasa »
Error
Velecasa
#15 Post by Velecasa »
I sucks being computer stupid ! Lol
#16 Post by Garm »
besides the stamp, there is an aluminum plate with it as well. I think someone posted the location of that earlier.
#17 Post by subaru360nut »
My reply on this disappeared too.
Remove the spare tire, look at the metal
"crossmember" below where the tire was,
wash it if necessary
THERE IS THE VIN, STAMPED IN THE METAL;
#18 Post by books1 »
Is that the small aluminium "tag" that is usually found attached to the jack holder bracket? If so, I don't think it is the same number as the VIN, at least not in my case anyway.
#19 Post by Garm »
It's not the VIN. My sedan had it too.
Gamestermike89
#20 Post by Gamestermike89 »
So if someone says they have a "matching numbers" subaru 360. Are they full of it? Or is the number actualy somewhere on the chassis and engine somewhere?
1969 Subaru 360 sedan
1982 Cadillac Fleetwood brougham.
1999 Toyota Camry (every day beater)
#21 Post by subaru360nut »
"matching numbers" means nothing on a 360.
The VIN for a sedan is K111L-(4 or 5 digits)
The only thing that matches it is the title :lol:
Engine # is not important and is nothing like the VIN
"matching numbers" is in a class with "very rare"
and "less than 100 imported" :twisted:
#22 Post by books1 »
- and "ran when parked" :lol: :lol: :lol:
Gamestermike89
#23 Post by Gamestermike89 »
Thats sad. I was hoping to match thoes up.
